Help with Word 2002
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I wonder if any one can help with a slight problem I have with Word
2002.
It came with my computer about 2 years ago in Works Suite 2003.
The problem is that I cannot copy and paste from another program if
Word is running and sitting on the taskbar. If Word is not running,
and I copy a program and then start Word, paste is grayed out.
I think, but am not certain that it worked o.k when I first got the
computer. I have removed Word 2000 from the computer and reinstalled
Word 97 from an old computer, and that doesn't have the same problem.
Paste is showing whether I have the program running or not. Would SP2
be the cause of the problem? as when I got the computer it wasn't
available.
Hoping someone can say if I have a problem or not.
Thanks
Alan Keatinge
If Word came installed as part of Works Suite then the Microsoft Works
Suite Add-in for Word (COM Add-in) is known to clear the contents of the
Windows Clipboard when Word starts.
Start Word first, then copy and paste.
Or follow the procedures here to remove the Works Suite add-in
WD The Windows Clipboard Content is Modified When Word Starts
http://support.microsoft.com/default.aspx?scid=kb;en-us;555173
This applies to Word 97, Word 2000, Word 2002 and Word 2003.
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:cmn351h1eghqsqeq0bua4pkco3d5jkof65@4ax.com,
Alan Keatinge <akeat@paradise.net.nz> hunted and pecked:
> 2002.
> available.
> Thanks
> Alan Keatinge
On Mon, 4 Apr 2005 19:01:42 -0600, "Wesley Vogel"
Thank you very much for the information. It works perfectly now.
Alan Keatinge
Alan,
You betcha. This had me confused for a long time.
Keep having fun. 🙂
Wes
In news:ti64519vv0mat4fdt56nif2fldi8gttq8i@4ax.com,
>> Works Suite Add-in for Word (COM Add-in) is known to clear the
>> contents of the Windows Clipboard when Word starts.
> Alan Keatinge
