J jacka41977 Honorable May 12, 2012 1 0 10,510 May 13, 2012 #1 Hello, my sound card does not support UBYTE4N can u help me
DM186 Splendid Aug 23, 2011 3,086 0 21,460 May 13, 2012 #2 If that is the case go back to the onboard sound. To do that go into your device manager under sound disable the card and you should default back to integrated sound. Good luck Upvote 0 Downvote
