help
Von
46
Archived from groups: microsoft.public.windowsxp.basics (More info?)
i need to konw how to save music from a cassette tape to
my pc i have it hook up i need to konw what progman to
used to do this with. thanks von
http://www.delback.co.uk/lp-cdr.htm
Although it refers to LP to CDR you may be able to plug your cassette recorder/stereo
system into the PC depending upon what you are using. Anyway I hope this helps you.
If not continue the www.google.com search.
I used Cool Edit to convert all my LP's to CDR but Cool Edit has been taken over by
Adobe. I had a record player with it's own amp which plugged straight into the
computer.
The site also lists some programs which may be of use to you.
Good luck
"von" <anonymous@discussions.microsoft.com> wrote in message
news:3e3801c49fef$55273710$a301280a@phx.gbl...
