Help
marciebryant
PC Audio Support - Windows® 7
Conexant develops audio solutions that are used in a wide range of products including personal computers. We provide customized audio drivers to our customers, which include major computer manufacturers globally. At the request of these manufacturers, Conexant does not provide end-user support or drivers for PC audio products. If you have an issue with the audio configuration in Windows 7, please contact the manufacturer of your computer. tried to get hp to contact with information and still waiting and it has been since at least july of 2011 no success. I am unemployed and so price has been issue, I did purchase an external sound card and plug that in but speakers are going now, I would like computer back and work like when I purchased it.
Double click the speaker icon in the lower right hand of the desktop, this will bring up the mixer, or single click to bring up the volume control.
But in case the volume is missing, corrupted, or the audio is otherwise non-functional:
you check whichever audio was installed:
click start, control panel, add remove programs, look at the list...
which audio software is shown on the list? delete it, restart the computer.
now visit the motherboard manufacturer or computer manufacturer's website
look up your computer drivers by model number
download the latest audio drivers, save on the desktop...
turn the antivirus off,
if you have multiple security programs installed, turn them all off
(your driver may not install if security systems are turned on)
now load your new audio driver, restart, turn the antivirus back on.
Let the forum know if that solves the problem. SGM
