help
gunrun911
12
I have a p4 1.6 o/c to 2.1.. I have 512k ram. I have a gef ti 4200 128 meg video card.. The problem is, i dont want to a new computer since it is expensive and i am a newbie.. Is there anyway i can upgrade this one so i can run half life 2? i have counterstrike source and i get 30-40 fps on all low settings.. With counterstrike 1.6 i get over 90. I see the new half life engine takes up a lot of resources i guess.. any ideas? my motherboard is an asus p4s533. Someone told me to get get 1 gig of ram and a new video card and that should do it.. any ideas?
My motherboard has 3 memory slots, 1 which has the 512kram in it.. SHould i just buy another 512k ram? or get rid of it and buy 1 stick of 1 gig of ram? i dont want to mix 2 different memories together and have problems.. I have mushkin ram rated at 2 2 2 in the pc now.
What video card can i get to run this game? All i do is play games so im not concerned about anything else?
thanks.
We say 512mb.
Well, you can always get a r9600pro / xt ...but your cpu will hold you back a little.
Adding memory wont get you anything.
Click <font color=blue><A HREF="http://www.albinoblacksheep.com/flash/you.html" target="_new">HERE</A></font color=blue> if you realy are an <font color=red>idiot</font color=red>.<P ID="edit"><FONT SIZE=-1><EM>Edited by coylter on 09/12/04 03:59 PM.</EM></FONT></P>
ATI 9800 Pro Retail for $165 at NewEgg, or $150 elsewhere...
Then you will have graphic power to spare, and carry over to new mobo, if upgrade is AGP compatable...
Try everything...
Do not be afraid of failure, for this is how we learn and grow...
Live life to the fullest...
Do not regret what you have not yet done!!!
"To spare" is exagerated....
Upgrade your graphics card to Radeon 9800 Pro
<A HREF="http://geocities.com/spitfire_x86" target="_new">My Website</A>
<A HREF="http://geocities.com/spitfire_x86/myrig.html" target="_new">My Rig</A> & <A HREF="http://geocities.com/spitfire_x86/benchmark.html" target="_new">3DMark score</A>
P4S533 is a great board. My friend ran his P4 1.8A at 2.4B speed with RAM at DDR400! I think you can get more out of your CPU, I'd try around 166MHz bus to get it to 2.66GHz. I'll assume for a moment that you have PC2700 RAM (DDR333) to match.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
can i upgrade my p4s533 to 2.8 ghz? i think i can according to the asus website.. will this help? im running at 2.2 stable right now.. is it worth it , or not worth it..
The 9800pro will help the most.
Rather than spending $167. (P4b@ 2.8) for a 22% cpu gain, you should get an NF7-S ($87) and a 35w xp-m 2400+. This chip can OC to >P4c 3.2 perf.
But get the Radeon first.
