im i have been having issues lately with my cpu while playing all the cores are at 100% i have a intel i512400f with an a rtx 3060 and 16gb of ram 8x2
my cpu cores
my cpu cores
yeah it did not detect anythingHave you run anti-malware? Checked to see what is running and using the CPU? Are you running a backup?
my cpu cores
No nothingdid you switch out any components or upgrade anything
No nothing
Already did and updated my drivers also checked in steam and I don’t download anything while gaming I only have Fort-nite runningcheck for windows updates and new gpu driver updates.
check temps also in steam turn off downloads while gaming and steam overlay
Yeah I think it’s only fornite cause I played destiny 2 with ultra gráfics and got 130 it didn’t change and gta also but it’s weird that with a bug my cpu goes to 100% usage on all corestest it and see if any other game does this
i recently had a similar issue today with fornite literally knocked out my pc after a new update so they may have to patch fornite again
So yeah so I should just wait it out?fornites had alot of bugs lately they have been patching it like nuts this one def broke something cause im rocking
rx 7 5700
4070 super
32gb
and the computer just fell over zero reason why apart from causing my cpu usage to go nuts.
whatever the reason its causing a all cpu work load which is kind of daft as its not that intensive
Okay thanks
