mumart
I don't see all my i term on my external drive and i didn't click safe remove before i unploughed the drive how do i solve the problem
Hawkeye22
Champion
If you didn't use the "safely remove" option before unplugging the drive then you won't be able to retrieve that data. Windows uses write caching, so by unplugging the drive first, any data that was in the cache never got written to the disk and is lost.
mumart
Thank you for your respond.the problem is that when i fixed the hard drive you will see that you have file which has taking the bigger size of the drive. but when i open the drive i see only few
Hawkeye22
Champion
1. Run chkdsk x: /f substituting x with your drive letter.
If you still have problems then...
Is the file hidden? You can go into the folder options and tell it to show hidden files. You may also want to try windirstat. It will show you a grphical representation of your files and folders.
