High CPU Usage help!
cklaubur
In your first picture, avgnsa.exe, Steam.exe, and System are together using about 94% of the CPU. Avgnsa.exe is part AVG Anti-virus, Steam.exe is the Steam client, and System is a Windows process that covers multiple Windows functions, including disk access. Did you have a virus scan running or were downloading a game through Steam?
Casey
P.S. Bumping is unnecessary.
uthvag
1,115
188
what is your processor?
and what are your temps? sometimes there might be throttling due to high temps which cause this kind of thing
generally all the tasks are managed by the CPU and so is the % of usage (PS- avg occupies a bit of mem)
and what version of windows do you have (those screenshots look old)
Hope it helps!
Azuro
57
The second image is where I have closed all programs. Steam chrome etc...
Btw my processor is Intel Celeron CPU B820 1.70 1.70GHz
4 GB RAM
uthvag
1,115
188
your processor is a bit weak , but still it shouldnt lag that much.
what are your CPU temperatures (it might be throttling)
and what version is your windows?
4gb ram is also fine
+have you tried cklauburs method?
slyu9213
1,055
100
A bit weak? An 1.7GHz Dual-Core Celeron sounds really weak. But it shouldn't be a major issue though.
What I don't understand is that the CPU usage is 99% with Steam, AVG, etc on, but with everything off (minus Steam) it's still 90% when Steam is the only program using 19%.
uthvag
1,115
188
bit of an old habit of using bit with everythin...
slyu9213
1,055
100
That could be true but if you look at both screenshots the Task Manager is set up to show the processes that are using the CPU the most, hence why they are listed in CPU load order (46, 31, 17, 2, 1.... or 19, 5, 3...). Also the list seems to be scrolled to the upmost top where all the processes using the CPU should be listed.
cklaubur
However, the second screenshot shows the button that needs to be pressed to show all the processes, while the first one shows a checkmark instead.
Casey
Azuro
57
My Windows version is Windows 7 Home Premium 64 Bit
Not sure about the temp. thing though. If you mean by that the fan part then no, no problems at all.
uthvag
1,115
188
well , check your CPU temperatures. if it is high it might cause throttling to lower frequencies
other than that ,if nothing works try formatting your system
Sorry, out of ideas!
PS- try unistalling AVG and or/ other demanding software and check if you have any bloatwares
Similar threads
