High FPS ( +90 ) With 144hz monitor, But its feels laggy like 35fps.
encise
Commendable
Aug 21, 2018
115
Hello, I always get +80FPS on Fortnite ( Highest Settings ) , With my GTX 1060 3GB , And i7-8700k overclocked to 5Ghz, i do have 144hz montior, my problem is when i play fortnite on 70-95fps its feels like 30fps , i don't know why, When i change the settings to low i get over 200fps and its feels like 144hz, but when i back it to maximum settings its feels like 30fps when i play on 70-95fps , I tried V-Sync on and off, i tried reinstalling my windows, What's the fix that's really annoying, and the temp are good CPU temp is like 70 on maximum load, and gpu temp is good too what to do?
And by the way its not playable, its really feels like 30fps its not because i use 144hz now and i see 80fps laggy, no its really not playable.
I use XL2411 BenQ Monitor ( 144hz )
i7-8700k
gtx 1060 3gb
16gb ram
750w bronze psu
Yes i have 2x8, i gave to to someguy to install it to me, I don't know in wich slot but i guess its on 1,2, Tell me what's the best to change it , My exact brand of ram is the hyperx 2x8gb 2133hz, And my mobo is " MSI Z370M MORTAR LGA 1151 (300 Series) Intel Z370 HDMI SATA 6Gb/s USB 3.1 Micro ATX Intel Motherboard " let me take another benchamrk while closing everything really quick..
Here is it i think now its benchmark the gpu now: http://www.userbenchmark.com/UserRun/10797505
i bought my mobo from newegg here is it: https://www.newegg.com/global/sa/Product/Product.aspx?Item=N82E16813144114
And also i don't really care about the USB its just 32gb Sandisk
I meant it's convenient that you have one as you need the USB to update BIOS. Your motherboard is not identifying the RAMs correctly.
Also, install it like this on 2,4. unlocking the side clip first. Or watch a video as nothing is better than a visual guide.
Okay should i update the BIOS and Change ram slots and then send another Benchmark?
Okay thank you, i will update you
Well, i updated my bios and then i turn my pc off to check the rams, and it was already installed correctly,
Idk if the problem got fixed, i will try now, but i saw my cable management is horrible look: https://prnt.sc/ktbswt
Does that produce an effect because the guy who build my pc was not that good i guess?
No, im sure 100% im using 16gb ram with dual channel i saw that on CPU-Z and on the other benchmarks apps
