Hi everyone. I am currently living in a pretty crowded area with tons of internet users (there are 47 networks around me that I can connect to, with a lot more outside of my WiFi adapter's range.) My problem is that I experience huge packet loss in the connection between my router and my stationary PC, as can be seen on the attached screenshot from PingPlotter. As I am a person who plays games frequently, this results in intolerable latency spikes, and gaming online is pretty close to unbearable.
These are my specs:
What I've tried:
I've identified the WiFi USB adapter to not be the problem, as my laptop with a built-in WiFi, even when placed right next to the router, results in very large packet losses too, although placing it closer to the router results in a packet loss percentage of 30-35% instead of the 49% experienced when moving around 6 meters away and behind two walls from the router.
So ultimately, these are my questions:
Below, the screenshot of a ping test done in PingPlotter:
These are my specs:
■ Router: TP-LINK Archer C2
■ WiFi USB Adapter: NETGEAR A6210
■ I'm running a 5GHz connection, but the same thing happens when I switch over to 2,4GHz, regardless of the channel I use.
■ My PC is the only device connected to the router
What I've tried:
■ Connecting a laptop with built-in WiFi both through WiFi and cable, cable results in no packet loss, while WiFi does result in packet loss, which makes me think it's either a faulty router or huge congestion of traffic
■ Changing frequencies and channels
■ Restarting my router to factory settings
■ Turning off my router for longer periods of time to see if that will make it chill out somehow, but it didn't ;(
■ What else can I do to pin-point the source of the issue?
■ Am I right to assume it's either a problem with the router or the congestion?
■ If it is the congestion, is there anything I can do to improve my situation?
