Highest resolution on monitor just not right...
TK61951
47
I have a Gateway FHX2300 Widescreen monitor. I'm still trying to figure out what graphics card I need, because I'm having
issues dealing with the monitor's resolutions. Right now I have it reduced to 1600x900 because I can actually read stuff this way.
My native/max resolution is 1920x1080, but EVERYTHING IS TOO SMALL!!! Seems everybody else (friends) has relatively same
sized monitors at same max resolution, and they everything shows normal, but not mine. Is it because mine's a widescreen?
What can I do besides wearing glasses to have max resolution and actually be able to see *** without squinting? In the case
that I will just have to deal with a 1600x900 resolution, whats the maximum VRAM I should get on a graphics card?
Thanks for any help!
keep on maximum 1080p and just increase the size of everything.
In windows 7 for example right click on desktop >> select Screen Resolution > look on bottom for "Make text and other items larger or smaller. And even Adjust text DPI to make as big as you want.
need to know what operation system you have but its possible to make on any
