Question Hogwarts legacy; do these specs work?
ushyisbest
32
COUGAR MX330-G Air Mid-Tower Case $59.99
EVGA SuperNOVA 550 Ga 80+ Gold 550W Modular Power Supply $54.99
ASRock B660M STEEL LEGEND $114.99
Intel Core i5-12400F $177.99
Buy DEEPCOOL GAMMAXX400 CPU Air Cooler with 4 Heatpipes, 120mm PWM Fan and Blue LED for Intel/AMD CPUs (AM4 Compatible): CPU Cooling Fans -
DeepCool GAMMAXX 400 CPU Cooler $15.99
TEAMGROUP T-Force Vulcan Z DDR4 3200 16GB (2x8GB) CL16 $50.99
PNY CS1030 1TB M.2 NVMe PCIe Gen3 x4 Internal SSD $69.99
ASRock Challenger D Radeon RX 6600 XT 8GB Video Card $329.99
System Requirements
Minimum:
  • Requires a 64-bit processor and operating system
  • OS: 64-bit Windows 10
  • Processor: Intel Core i5-6600 (3.3Ghz) or AMD Ryzen 5 1400 (3.2Ghz)
  • Memory: 16 GB RAM
  • Graphics: NVIDIA GeForce GTX 960 4GB or AMD Radeon RX 470 4GB
  • DirectX: Version 12
  • Storage: 85 GB available space
  • Additional Notes: SSD (Preferred), HDD (Supported), 720p/30 fps, Low Quality Settings
Recommended:
  • Processor: Intel Core i7-8700 (3.2Ghz) or AMD Ryzen 5 3600 (3.6 Ghz)
  • Memory: 16 GB RAM
  • Graphics: NVIDIA GeForce 1080 Ti or AMD Radeon RX 5700 XT or INTEL Arc A770
  • Additional Notes: SSD, 1080p/60 fps, High Quality Settings
Yeah, you should be able to play the game on recommended high quality settings, though depending on the resolution you can still adjust and change graphics settings to your liking.
Your current PC specs do meet the requirements.
