like others earlier I strongly recommend looking at CUDA. CUDA uses
Start here: http://www.nvidia.com/object/computational_fluid_dynamics.html
Then check your software to see what is supported.
If you care about your results, consider waiting for the next gen from nVidia codenamed “Fermi”. It actually has error checking so you won't need to re-run your code a few times to see if you got the right results or if a sunspot flipped a bit on you. (RAS of current accelerators is mostly missing because they are built from graphics cards that don't care about data integrity)
Suggest: Append to CUDA forums describing your application needs in CFD. Ask for config help, verify software works as advertised, check benchmarks.
Suggest: Start with a 'gamer' PC of your choice. Specify a high end nVidia graphic card. Cost will be $1K to $2K total from Dell or some specialty house. Get the software you need working with CUDA. If the performance is not there then you can consider higher end solutions. Don't throw $20K at this problem until you understand the ups and downs of the $1-2K system.
