So I'm thinking of building a HTPC, that will mainly be used for netflix, maybe some occasional gaming, i dont expect anything over 200 fps, something that gets me 90 fps consistently would be great if possible (havent decided whether to get a 1080p or 4k tv, will most likely get 1080p)
My budget would be $600 Canadian Dollars, before tax. The problem is that I dont know anything about best bang-for-the-buck pc components, and i was wondering if i could get some help for the parts to get. The only preference i have is ITX case and Motherboard, something small
Thanks in advance
Thanks in advance
