HOME VS PRO
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi all
Can someone please point out some of the advantages of XP PRO against XP
HOME ?
TIA
Guy
"Guy Cohen" <control@mediatek.co.il> wrote in message
news:uIz8ScDuFHA.3068@TK2MSFTNGP14.phx.gbl...
> Hi all
> HOME ?
> TIA
see
http://www.microsoft.com/windowsxp/home/howtobuy/choosing2.mspx
http://www.microsoft.com/windowsxp/pro/howtobuy/choosing2.mspx
Regards,
Mike
Mike Brannigan [Microsoft]
This posting is provided "AS IS" with no warranties, and confers no
rights
Please note I cannot respond to e-mailed questions, please use these
newsgroups
> Hi all
> HOME ?
> TIA
> Guy
Hi Guy,
The core operating system is the same. Differences:
- WinXP Pro will allow 10 inbound connections, Home only 5
- Pro has policy editors (useful in a corporate environment)
- Pro has IIS (useful if you build server apps)
- Pro can become part of a domain (another corporate use)
- Both use simple file sharing by default, but it can only be disabled in
Pro
- Firewall and file security between users is the same
- Encrypted file system is only available in Pro
If you need any of the benefits of a Pro system, then go with it. Otherwise,
most home users are happy with XP Home.
More details:
http://www.microsoft.com/windowsxp/home/howtobuy/choosing2.asp
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
> Hi all
> HOME ?
> TIA
> Guy
"Guy Cohen" <control@mediatek.co.il> wrote:
>Hi all
>HOME ?
>TIA
>Guy
The other responses have pointed out the major differences.
One important thing to remember is that there is zero difference in
performance or stability between the two versions (with the exception
of a PC with two CPU chips installed as Pro will use both CPUs and
Home will only use one). Both versions are compiled from the same
source code base.
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
Guy Cohen wrote:
> Hi all
> HOME ?
> TIA
> Guy
Without knowing the precise situation in which the OS is to be used,
and the exact uses to which the computer will be put, there's no way to
even say which version would be more "advantageous" to you.
The WinXP Home and WinXP Pro versions are _identical_ when it comes
to performance, stability, and device driver and software application
compatibility, but are intended to meet different functionality,
networking, security, and ease-of-use needs, in different environments.
The most significant differences are that WinXP Pro allows up to 10
simultaneous inbound network connections while WinXP Home only allows
only 5, WinXP Pro is designed to join a Microsoft domain (a crucial
capability at most universities) while WinXP Home cannot, and only WinXP
Pro supports file encryption and IIS. (Oh, and WinXP Pro usually costs
roughly $100 USD more than WinXP Home.)
Windows XP Comparison Guide
Which Edition Is Right for You
http://www.microsoft.com/windowsxp/whichxp.asp
Windows XP Home Edition vs. Professional Edition
http://www.winsupersite.com/showcase/windowsxp_home_pro.asp
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
NETWORKING
Home only supports Workgroup networking
Pro is designed for people who use a Domain network
This is the main difference between the two
Jayso
Please reply to this email so I know if i'm right :)
Good in Home Networking, XP Home based problems, and Pro based Problems
Add my email to MSN Messenger if u wish
jayso_chinnery@spamfreehotmail.com.au (remove spamfree)
> Hi all
> HOME ?
> TIA
> Guy
