Hook up case fans on NZXT Phantom 530
Msiebenaler
15
I am a little confused about how my fans are supposed to work. I just built my computer on my own and I can't seem to figure out how to get the case fans to spin. Could someone please look at my parts list and see how they are supposed to hook up?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ SuperBiiz)
Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($198.99 @ Newegg)
Memory: Corsair Vengeance LP 8GB (2 x 4GB) DDR3-1866 Memory ($56.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card ($197.99 @ SuperBiiz)
Case: NZXT Phantom 530 (Black) ATX Full Tower Case ($119.99 @ Micro Center)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($109.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($18.89 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($89.95 @ OutletPC)
Sound Card: Asus Xonar DSX 24-bit 192 KHz Sound Card ($42.49 @ SuperBiiz)
Wireless Network Adapter: TRENDnet TEW-684UB 802.11a/b/g/n USB 2.0 Wi-Fi Adapter ($28.98 @ OutletPC)
Monitor: Acer GN246HL 144Hz 24.0" Monitor ($222.99 @ Amazon)
Speakers: Logitech LS11 3W 2ch Speakers ($21.49 @ Amazon)
Other: Mouse pad ($12.99)
Total: $1411.70
Hook your case fans up to the motherboard fan headers.
Yea I tried that. They are three pin and the motherboard headers are four pin and they don't fit. I've heard that they are supposed to be compatible for both three and four pin but they just do not work/fit:/ Do I need some type of adapter or something?
One that case there is a built in fan controller and fan hub. You need to connect the molex connector that comes with the case to the power supply. It will power the fan hub and controller which will power the fans.
There isnt a need to hook them up to the motherboard at all.
So, what ARE these two cable for then, that are part of the case?
ry%3D400
