[SOLVED] Hotspot recommendation, home use.
AtotehZ
403
13
18,815
Hello guys,
My mom lives in a home of a decent size and has trouble making her router's wifi reach all corners of her home. I've decided the best way to help her is to get 2 hotspots that'll be plugged into the router. Cable will be run between the router and hotspots.
Which budget hotspots would you recommend for a home like this? They don't need extreme range. If each of them have a "normal" range it will do.
If a hotspot would be the wrong solution I'm willing to listen to that as well.
You will have much better luck when you use the correct term. The better name for a wifi source connected via ethernet cable is "AP". You can buy actual AP if you really want but I suspect since you do not know what they are you do not need many of the special features.
Likely you best option is to buy a mid price router to function as a AP. Many of these devices have a setting that makes them run as AP rather than a router. Even if it doesn't pretty much any router can be used as a AP. It is trivial to setup just search how to use a router as a AP.
Preferred site wouldn't help you since I'm in a small country and none of the known sites would help you. Ill sort out the pricing.
For now im looking for something under $400 for the whole project, that should be possible and I suspect it can be done a lot cheaper.
The router is, generic crap to be honest. I think it's a Sagemcom F@ST 5345, but it has been stripped of all identifying text and stickers. It came with the net, they have dsl. It has 4 rj45 ports though. That's why I wanted a cabled hotspot, they don't mind pulling the cable. Can extenders run cabled?
2x 60ft radius I think.
I'm thinking something like:
1x Zyxel ARMOR X1 for the hotspot.
A new router with a better antenna,
Sorry, but im gonna be honest here. Your comment is presumptuous.
Thank you for your suggestion regarding using a router as a hotspot, refrain from sharing your guesswork regarding what I know and don't know.
I used the term hotspot exactly because I know it is the correct terminology, maybe not as precise as 'access point' is but when I made the thread I wasn't certain about what I wanted. Hence the thread.
