My side panel had finger marks and I cleaned it with screen cleaner and a microfibre which normally does the trick for most things but surprisingly, it scratched the panel.
View: https://imgur.com/a/zwFETdE
Was wondering if I can fix it by using a clean microfibre cloth and Meguiars Ultimate Polish (normally for cars) to remove the scratch, or are there any other ideas ?
In the future, I think the best method would be a clean microfibre and a car detailer spray instead.
