how can i connect a wifi connection without using ethernet cable because my adapter settings dont have a wifi network connecti
Rose Ann2
Commendable
Sep 8, 2016
how can i connect a wifi connection without using ethernet cable because my adapter settings dont have awifi network connection its only a local area connection how can i fixed it
Sounds like you are mixing things up a bit. You don't use WiFi with an Ethernet cable, that is a wired connection. If you don't have a wireless option you may not have a wireless network card. A USB WiFi card is about $20-50 for a good model depending on your speed and range needs.
Do you have a NIC or wifi adapter? If not you can pick one up cheap or get EoP and use ethernet.
