[SOLVED] How can I switch my C: and D: drive?
Jun 17, 2020
Currently my C: drive is a 500 GB SSD with my windows installation and a couple games, and my D: drive is a 2 TB HDD. I want to make my 2 TB HDD my C: drive with my windows installation and the default place for apps to download and make my SSD my D: drive that is used for specific apps that I want to be faster. How do I do this?
  1. You can't just switch the drive letters around.
  2. Putting the OS on the 2TB is actually the way wrong way to go about this.
The SSD being the C drive is absolutely the best config.
If you use Steam games, you can install on both/either. And make whichever the default install location.
Origin has a similar function, I believe.
For other applications, you choose where they install to when...
For other applications, you choose where they install to when you install them.
Things that don't need the SSD speed (doc/music/movies...store them on the HDD.
Okay, thank you
