How can I use both my gaming headset and my speakers through the same PC sound c
mpjester
Hello, I have an awesome Creative Fatality Champion sound card and want to be able to switch between my ROCATT gaming headset and my speakers at will. How can I accomplish this task?
set the front jacks for your headset and the rear for the speakers. then go into the creative panel and select mute speakers when front jacks are pluged in... this will mute the speakers 😉. if you dont use that then the speakers will stay on regardless of what is plugged in the front jacks.
Hello HEXiT, sorry I didn't respond to this earlier. I've been very busy! :bounce:
I will try to explain how the current setup is and see if you have another solution. The ROCATT headphones are 5.1. I'm using almost all the inputs (color coded on the sound card) for the headphones except the one extra (blue) for my speakers to plug into. If I use the front jacks, will I still get 5.1 from my headset? I don't think I will. I was also thinking it my be a BIOS driver update issue or my Realtek audio driver on the MOBO.. :??: Anyway, there must be a way to be able to switch at will between the headset and speakers using the awesome sound quality of this sound card. All suggestions are welcome. Thanks! :)
Oh, and since you are showing your system features I thought I would show mine.
i7 940 (no OC), Coolermaster V8, EVGA X58 Mobo, 6GB Corsair-Dom1333, GTX 480, X-fi Creative sound blaster fatality champion, Dual WD Velociraptor 300GB, Turbo-cool 1000watt, Razer Blackwidow keyboard, Dual gaming mice (Rocatt Kone&Mionix 5000), M-Audio speakers, Rocatt Alumic mouse pad, Rocatt Apuri USB hub, Rocatt Kave headphones
