How disable shell folder for CD burning ?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.perform_maintain (More info?)
RegMon shows that very frequently I access this device number.
{fbeb8a05-beee-4442-804e-409d6c4515e9}
This device number is something to do with the "shell folder for CD
burning".
I haven't burnt a CD for about a month. If I do any burning I use
Nero and not XP.
Whatever it is, can I disable the "shell folder for CD burning"?
Hi Zarbol Tsar,
Disable XP's native CD burning support by opening My Computer,
right-clicking on the icon for the burner, going to Properties then
Recording tab, and clicking in the checkbox beside "Enable CD recording on
this drive" to clear the checkmark, then clicking on Apply then OK.
Regards,
Patti MacLeod
Microsoft MVP - Windows Shell/User
"Zarbol Tsar" <zarbol@tsar.net> wrote in message
news:95D7DF6625A0651D7E@130.133.1.4...
> burning".
> Nero and not XP.
You can also put a stop to WinXP's built in CD burning support by disabling
the 'IMAPI CD-Burning COM Service'.
(Admin Tools>Services).
martin.
"Patti MacLeod" <pam120@nospamshaw.ca> wrote in message
news:eRgYQUQ9EHA.3120@TK2MSFTNGP12.phx.gbl...
> Hi Zarbol Tsar,
> Regards,
> Patti MacLeod
> > burning".
> > Nero and not XP.
