A aod626 Reputable Nov 14, 2016 22 0 4,510 Feb 23, 2020 #1 I have Dell dimensions 9150/xps 400 im connected with vga cable onto my Asus vg245h. i tried updating it and uninstalling it and I still can't figure how to fix it im running on Windows 10 pro.
Solution anotherdrew Feb 23, 2020 @aod626 Generic or not, does it show at the right resolution and refresh rate? If so, then what is the problem? If it really bugs you, try a digital connection (HDMI or DVI to HDMI)
anotherdrew Admirable Dec 27, 2017 2,005 110 7,790 Feb 23, 2020 Solution #2 @aod626 Generic or not, does it show at the right resolution and refresh rate? If so, then what is the problem? If it really bugs you, try a digital connection (HDMI or DVI to HDMI) Upvote 0 Downvote Solution
Pimpom Distinguished May 11, 2008 575 43 19,140 Feb 26, 2020 #3 Have you installed Asus' driver-utility software for your monitor? https://www.asus.com/Monitors/VG245H/HelpDesk_Download/ Upvote 0 Downvote
