So I decided to put my 'Toshiba 1TB drive' from an older config inside my current one. I checked that the SATA rate was the same and it is.
After putting it in I found this error message and I dunno what it means.
SMART detected HDD/SSD failure 6 : TOSHIBA DT1ACA100
WARNING! Please back up your data and replace your hard disk drive
WARNING! Your HDD/SSD might crash at any moment
The drive contains a copy of windows and some other useless files (which I in the end want to delete), unfortunately I don't have an extra config where I could reset the drive. Even after diabling the windows partition and the storage part of the drive, it would still give this message.
If you could tell me how to fix this I'd be great, you can find a pic of the drive here
(PS: I don't have any backup of my computer)
