R reubenanino Reputable Jul 12, 2015 1 0 4,510 Jul 12, 2015 #1 Is it possible to reformat a laptop or PC without using any hard drives or any formatting drives? Please help
Solution Phillip Corcoran Jul 12, 2015 You can format the system drive by booting a PC or laptop from a Windows installation CD/DVD or from a partition-management utility CD like this one: http://www.partitionwizard.com/partition-wizard-bootable-cd.html Download the ISO file CD image, create a CD from it, then boot your laptop or computer from it. How to create a CD from CD image? - use the free IMGBurn: http://filehippo.com/download_imgburn/
Phillip Corcoran Titan Moderator Sep 7, 2013 26,114 916 120,140 Jul 12, 2015 Solution #2 You can format the system drive by booting a PC or laptop from a Windows installation CD/DVD or from a partition-management utility CD like this one: http://www.partitionwizard.com/partition-wizard-bootable-cd.html Download the ISO file CD image, create a CD from it, then boot your laptop or computer from it. How to create a CD from CD image? - use the free IMGBurn: http://filehippo.com/download_imgburn/ Upvote 0 Downvote Solution
