DeviceManagerSteve? Aug 12, 2020 26 0 40 Aug 25, 2020 #1 Left CTRL + Left Shift changes the keyboard settings -- ? becomes É. How do I stop that from happening, permanently? Thank you
Solution zero_l0gic Aug 26, 2020 Remove all unnecessary layout, you probably press hotkey to change key layout. and you can always just remove the keys
zero_l0gic Reputable Aug 17, 2018 429 15 5,315 Aug 26, 2020 Solution #2 Remove all unnecessary layout, you probably press hotkey to change key layout. and you can always just remove the keys Upvote 0 Downvote Solution
