How does length of the VGA or HDMI cable affect the quality
Basically, if they manufacture a cable, it will work. No matter the length. They wouldn't make them if they didn't work.
DVI is same as HDMI. It will either work or not. The signal quality does not degrade. It just stops working.
Well, technically he is right, they aren't likely to manufacture a cable that the signal quality would degrade on, but you can certainly buy the HDMI cable material and create your own, but yes, they probably won't sell in store a pre-made cable that is too long to keep the signal.
