how does send ctrl + g to remote pc?
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
I work at home and use windows xp to connect my office pc. it works.
I need send a ctrl+g to remote pc. (a application needed)
I have tried it and does not work.
any ideal?
Thanks in advance!
ld
> any ideal?
That's strange.
In a remote desktop session, I just tried it (CTRL+G) and it worked fine.
(In notepad, it does a "goto line".)
What "application" is this? Does it work in your remote desktop notepad as
it did mine?
(In other words, is it the application or is it the keystrokes?)
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
"Shenan Stanley" <news_helper@hushmail.com> wrote in message news:<#0evewwzEHA.2572@tk2msftngp13.phx.gbl>...
> > any ideal?
> That's strange.
> it did mine?
> <- Shenan ->
Thanks Shenan!! It works. I use ibm notebook. left CTRL does not work,right
CTRL works. Thanks again.
