I've gone through about a dozen attempts to push in the 24-pin PSU power cord into my ASRock Z68 Extreme 3 Gen 3 motherboard, but stopped each time as the motherboard was bending in slightly and I was pushing hard enough to tip the case.
I've already plugged in the 8-pin 12V power connector into the mobo with very little problems, and managed to get both 6-pin PCIe cords plugged into my GPU after a lot of struggling and demoralization upon hearing "crinkling" sounds due to force, making me worry that I broke the graphics card.
I've double and triple checked, and yes, this is the right cord, and yes, my mobo has the right 24-pin slot for it, and yes, I'm pushing it in on the proper side, matching the little secure-lock clip up with its surface pair.
I'm just really worried about damaging my motherboard, and this whole process of building my PC has been a process of freaking out and worrying. I'm hoping that mobos and GPUs are a bit sturdier than I think, but still, I'd like to stray on the safe side, and thus I ask if anyone can tell me if it would be okay to push even harder than I'd like to in order to get the plug in.
Also, is it normal for motherboards to bend a lot? Pushing the RAM in was quite worrisome...
Thanks for the help.
Sincerely,
A worried builder.
Sincerely,
A worried builder.
