How hot should a liquid cpu cooler's radiator be?
KeepThoseEyesOpen
12
Pretty much what the title says, my radiator gets pretty hot and was wondering if that is normal. I only have one fan placed on it which is pushing air through the radiator. The reason for this is because I don't have enough room for a second fan in my case.
Yea I figured that as well, better the radiator then the cpu, but then I wondered if there was a limit to how much heat the radiator can with stand. And I can technically do a push/pull setup on my antec h20 620 but the problem is the case. I'm unable to screw the bottom mounting bolts because the fan that is pulling the air isn't lining up, so basically the fan isn't fully attach to the radiator making it hang off from the bottom.
They're good, thanks for the reply. :]
