How many fans can i connect to my motherboard?
HeartbeatSensor
19
Hello ,
So i have an ASUS B150M PRO GAMING motherboard and i have a Zalman z9 Neo black which
has 5 fans.Can i connect all of the fans into my motherboard?If not how many can i connect?
Go here and look under the "Internal I/O" section - https://www.asus.com/Motherboards/B150M-PRO-GAMING/specifications/
You have a header for one case fan. It is located near the back panel ports
EDIT: Doing a little digging. I can see that the top two case fans can be powered by your power supply using Molex connections. This is good news as you won't have to use your mobo for them. The rear fan does have a 3 pin connector, so you will have to put that one onto your motherboard header.
I can't tell if the 2 front fans have the power supply connection or not.
