Question How much does intake / outake effect cpu water cooler?
jase888
176
So I am looking at the Lian Li PCO11 Dynamic Case with the Corsair 150i Pro CPU Cooler (switching the ML fans for LL). However with this case & using LL fans it seems the only option is for the CPU Radiator to be used as outtake at the side or top. So wondering how the CPU cooling would be if it was outake rather than intake?
If there's a better way to do this let me know but the LL fans cannot be turned around since RGB lights are on one side which is intake.
It's visible from both sides though?
