Can someone tell me how much electricity my 115w fan uses per month if I leave it on for 12 hours a day in a month? The cost of electricity is .1332kwph
Thank you!
Sorry didn't know which category to put it in
Your Fan takes 115Wh * 12h a day
Is 1380Wh/day*30days = 41400Wh
41400Wh/1000 = 41.4kWh per month
41.4kWh * 0.1332 >> 5.51448 £€¥$/month whatever currency you use.
You are aware that number will be completely different depending on what currency you use right? $ =/= € =/= £ =/= ¥ =/= ₱ =/= ₹
No it won't.
OP said 0.1332 not specifying which currency.
So I don't know if OP meant 0.1332 £€¥$
But according to the currency used by OP, that'll be the cost in that unspecified currency.
I thought this would be obvious. Sry.
Plug the meter into the wall, plug the fan into the meter. Run for time x
Read Kill-o-watt meter after time x. See how many watts were actually used (versus fan rating) and then do calculations as suggested in preceeding posts.
