how much is too much degrees for gt 1030?
odiukurac70
99
i was just wondering if i can let my gpu run at 85 degrees for better performance, the card is passively cooled though, so i cannot crank up the fans or anything, and i was thinking about selling it and buying the one with the fan on it
Yes.
You might find you get better performance and temps if you just strap a fan to it though.
That card is the lowest end card of the current gen. Letting a card run at 85 degrees is not necessarily going to give you any performance benefit. What are your system specs and what kind of temps do you see on the card when you play a game?
i overclocked it, but the core clocks are all over the place, and i'm sure it could perform better if i let it run at 85 degrees, the temp limit is 80.
Why did you ask a question to the forum and then answer it yourself?
i didnt i just replied to him
I have gigabyte gt 1030 2gb oc edition when i play game temp from 65 - 75°C. It is temp too high compared to normal because when i vewving reveiw of gt 1030 temp it only only 55 °C.
