TwenteMaster Aug 24, 2019 4 0 10 Apr 17, 2020 #1 if the CPU is AMD 3950x and GPU is AMD radeon vii, how much power do I need? is 850W power supply too much? thanks!
Solution siaan312 Apr 17, 2020 That is rather a high end pc. I would go with a minimum of 650w, But thats cutting it quite close. 750w if you wanna be comfortable 850w isnt that much of a long shot but it is a lot.
siaan312 Splendid Jun 15, 2017 2,319 459 23,790 Apr 17, 2020 Solution #2 That is rather a high end pc. I would go with a minimum of 650w, But thats cutting it quite close. 750w if you wanna be comfortable 850w isnt that much of a long shot but it is a lot. Upvote 0 Downvote Solution
