how obtain maximum graphics for my pc?
chanu0011
87
hello frnds..my pc config is intel DZ75ML-45K,i5-3330,4GB RAM..OS is windows 7 ultimate 32 bit.i have updated my pc to latest BIOS,vga driver also..games like NFS the run,NFS MW 2012,NFS RIVALS..not running smoothly.my processor supports intel HD 2500 graphics..maximum graphics memory is 1425mb and windows experience index is 4.9..dierct x is 11..pls help
Here is a good answer: Get a NVIDIA GTX 780ti and when you pop in the GPU, install the card drivers, then QUICKLY restart the computer, enter BIOS, disable onboard GPU, set the card to initiate first, then save and exit. Boot the OS, and if that card is working properly, you are good to go! Don't forget to plug in the VGA/DVI cables into the card.
DON'T FORGET TO SELECT A BEST ANSWER!!!
Cyanide Reverse
173
According to your other thread, I recommend upgrading to a I5 3570 as it has Intel HD 4000 integrated which at medium resolutions can run games quite smoothly (It will do the games you listed) and/or you can buy a graphics card to run the games.
