Archived from groups: microsoft.public.windowsxp.perform_maintain (
More info?)
>-----Original Message-----
>Bobby wrote:
>> "Recording Control" is what the window is
labeled...the
>> sliders that I have are "Recording, Stereo Mixer, Mic,
>> Line In, CD Player".
>>>I don't have a slider called Recording Control on my
>> mixer, so I'm afraid I
>>>can't offer any advice.
>>>Modem Ani
>>>"Bobby" <anonymous@discussions.microsoft.com> wrote in
>> message
>>>news:03e301c530b4$adbe8d00$a501280a@phx.gbl...
>>>>When I go to the "Recording Control"...the column that
>>>>says "recording" is not able to be moved.
>>>>>To find the mixer built into Windows XP:
>>>>>Control Panel - Sounds and Audio Devices - Volume
>> tab -
>>>>Advanced button.
>>>>>To find the mixer that came with the software for
your
>>>>sound card:
>>>>>Consult the software's Help file or user guide.
>>>>>Modem Ani
in
>>>>message
>>>>>news:02ac01c53096$b8061080$a501280a@phx.gbl...
>>>>>>I need to access the sound card mixer controls to
>> fix
>>>>>>something for the Sound Recorder on my Windows XP.
> This is in reference to Windows Mixer (aka Volume
>Control). In the Options area, click on the recording
>button. In the list below, check or un-check the items
you
>choose. Below each item displayed after closing options,
>check which control you want to use. Please note that
the
>slider will only operate on the one(s) checked.
>If they won't, you may have some file fragmentation or
>corruption, causing it not to function.
>Lester Stiefel
>In Romans 1 there are qualities of Unregenerate man
listed
>which describe him in the last days.
>Is your quality found on this list??
To: Lester Stiefel
How do I fix the file fragmentation or corruption?
