How to can I check if my XP OS is a 32bit or 64bit? I have a Dell Dimension E 510
Shpati Distinguished Dec 16, 2008 429 0 18,810 Dec 24, 2008 #1 How to can I check if my XP OS is a 32bit or 64bit? I have a Dell Dimension E 510
Ijack Splendid Jul 30, 2008 7,099 0 28,010 Dec 24, 2008 #2 It's almost certainly 32-bit. Check for the existence of the folder C:\Program Files (x86). If that's there it's 64-bit, if not it's 32-bit.
Z Zoron Splendid Jan 11, 2002 5,435 0 26,160 Dec 27, 2008 #3 Unless you specifically request 64-bit Windows XP when you order your PC, it will be 32-bit XP. Win XP x64 was an option... it never came standard from any OEM.
