Ok, so I'm looking to get either a 7870, or if i find a GREAT deal on a 7950, i'll go for that. But i'm patient, and waiting for a great deal on one, not just buying today regardless. So i'm researching them, and i THOUGH i only had to chosoe between brands...but man was I wrong! I thought that If i looked at (for isntance) HSI, they would have a 7850, 7870 & a 7950 for me to consider...but no. They have 3+ 7850's alone, and then I see one of their 7870's is actually cheaper than their 7850..? (granted, i know that 7870 was a great deal, and sold out almost isntantly because it was such a great deal*)
But i've seen similar stories elsewhere, with 7850's being just as if not more expensive than some 7870's, and some brands are having just blatantly higher prices...
Below is an example of what i am talking about.
Example at Newegg comparing 4 cards
Now, normally, I would just shrug it off and say it's pricing descrepencies and the cheaper ones are just much better value and the other company is charging more because people don't look to see if there are better options...but i don't want to make that assumption without some input first.
So...when i am looking at and comparing these cards to try and make my decision, and considering the value of any future deals, what do i need to look at when comparing same brand cards to distinguish between them, and are there any brands I should make sure to avoid, regardless of how good a 'deal' it may look like (ie - because they use really cheap/crappy components that fry easily, and then have horrible Customer Service to help me).
Also, although i'm more seriously considering Radeon's because they tend to be a better value, I am considering the nVidia's, mostly because i'm getting Borderlands 2, and the PhysX looks pretty dang nifty in it. Which of their cards would be comparable to the 7870, and what does their price tend to be around?
Thanks all!
Thanks all!
