xJesserX Reputable Jul 6, 2019 85 0 4,530 Jul 18, 2020 #1 as the title says how to clean a 1500r curved monitor ? ofc i need micofibre cloth but can i do it with some water ?
Solution hang-the-9 Jul 18, 2020 xJesserX said: as the title says how to clean a 1500r curved monitor ? ofc i need micofibre cloth but can i do it with some water ? Click to expand... Hope you got some curved cloth, most of the cloth out there is only for flat monitors. Get some amonia free foaming glass cleaner like this https://www.amazon.com/Sprayway-Glass-Cleaner-15-Ounce/dp/B07K1ZD36P/ref=sr_1_4?crid=2LEG0JQ1TLWGT&dchild=1&keywords=sprayway+glass+cleaner&qid=1595127916&sprefix=sprayway+,aps,159&sr=8-4 I use it all the time at work and home and it's safe on computer screens. Just remember you need to spray it on the cloth not the screen.
Math Geek Titan Ambassador Oct 15, 2014 18,747 2,734 104,090 Jul 18, 2020 #2 a very lightly damp cloth will work if it is turned off. but you're better off with some kind of electronic cleaner. plenty of wipes and sprays for the purpose. Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,372 1,081 152,940 Jul 18, 2020 Solution #3 xJesserX said: as the title says how to clean a 1500r curved monitor ? ofc i need micofibre cloth but can i do it with some water ? Click to expand... Hope you got some curved cloth, most of the cloth out there is only for flat monitors. Get some amonia free foaming glass cleaner like this https://www.amazon.com/Sprayway-Glass-Cleaner-15-Ounce/dp/B07K1ZD36P/ref=sr_1_4?crid=2LEG0JQ1TLWGT&dchild=1&keywords=sprayway+glass+cleaner&qid=1595127916&sprefix=sprayway+,aps,159&sr=8-4 I use it all the time at work and home and it's safe on computer screens. Just remember you need to spray it on the cloth not the screen. Upvote 0 Downvote Solution
