[SOLVED] How to connect 2k monitor to HDMI/VGA laptop?
FireVortex720
72
Hi,
I have a ASUS S400C connected to a Lenovo P27q-20 2k monitor via HDMI. The max resolution I am able to achieve is 1920 x 1200 because I think the laptop only supports an older version of HDMI. What do I have to do in order to get the monitor to achieve its max 2k resolution via my laptop? Note that my laptop only has a HDMI and VGA port.
Thanks!
Hi,
Thanks!
You didn't identify which CPU you have, but for example, that laptop was sold with the i5-3317U CPU. That CPU has the Intel 4000 HD graphics. According to this article on Intel's forum -- https://forums.intel.com/s/question...4000-hdmi-2560x1440-resolution?language=en_US The highest resolution supported via HDMI for the graphics processor is...
Hi,
Thanks!
You didn't identify which CPU you have, but for example, that laptop was sold with the i5-3317U CPU. That CPU has the Intel 4000 HD graphics. According to this article on Intel's forum -- https://forums.intel.com/s/question...4000-hdmi-2560x1440-resolution?language=en_US The highest resolution supported via HDMI for the graphics processor is 1900x1200. Which is what you have experienced.
You can't get maximum resolution with the laptop you have.
I unfortunately do have the i5 3317u!
