How to connect a card reader
shreyasi gupta
i dont know how to connect a card reader to the computer and i cannot find any cables to connect except the computer's usb cable which is not attaching itself to this please suggest what to do
Plug your card reader into the 3.5" bay. On the bottom part of your motherboard you will see a few input pins. Underneath of them if you look they are labeled. *Differs for different motherboard models*
USB1,USB2,USB3. the audio one is usally black and the farthest one to the back.
Okay now. The slot you are looking for is either of the USB ones. Which the pins look like this.
::::. or .:::: connect the cable from the card reader into one of these USB ports. *Warning do not force it in, if it does not go in easy. Check it is being pushed in the right way.
Now reboot.
--Awknathan
