How to connect power to graphics cards
I've already answered it, but some of the replies/posts were deleted, I guess.
I kindly ask moderators to delete duplicate posts that have not been answered... if possible.
So, another try: what graphics card and PSU using?
If the PSU does provide the required PCIe power cables, then there's no need for an adapter.
Apr 1, 2018
5
the PSU provides enough power. However it doesn't have a 6 pin connector, it only has two 4pins. All i want to know is whether i am supposed to connect both 4pins or just one. Because the connector that came with the graphics card has two 4pins on the other end that connects to the PSU.
maxalge
Champion
Herald
if your current power supply lacks the required cables
you need to buy a new psu
adapters are never recommended on sub par units
maxalge
Champion
Herald
the question HAS been answered
you need a new psu, using adapters on sup par psu's is asking for it to blow up/burn and take your pc parts with it
now as far as you "building" a custom psu... What are the specs?
Did you modify a unit? If so what make and model?
