[SOLVED] How to connect two devices to one ethernet port
Oct 10, 2019
8
I live in the student accommodation, which is a studio flat. I have an access to a single Ethernet port mounted in my wall. I have a PS4 and PC. At the moment the console is wired to the ethernet port and my PC is connected wirelessly using a wi-fi dongle.
I would like to connect them both to the Ethernet port. I read about ethernet splitter/combiner like this one: https://www.amazon.co.uk/StarTech-Splitter-Combiner-Required-Connection-grey/dp/B00009XSZE
But apparently in order for this to work I would need to connect another ethernet cable to router, and I do not have access to it. The only access I have is the previously mentioned single ethernet port. Could someone provide a solution (if one exists?)
They need to stop selling that crap. Way too many people thing you can just "split" a ethernet port and look for really cheap solutions. They are used to split the CABLE not the port. As you seem to know you would need 2 ports on the router, it just prevents running a second cable.
If you are very lucky you can buy a inexpensive switch. You can get 5 port 10/100 ones for about the same price as the splitter you list. I would still get a 10/100/1000. You can get a 5-8 port switch for under $20.
Will this work all depends on how many IP addresses you get. If the IP you get is private it is much more likely a simple switch will work. You can either look up what private/public means or you can compare the ip your PC...
Will this work all depends on how many IP addresses you get. If the IP you get is private it is much more likely a simple switch will work. You can either look up what private/public means or you can compare the ip your PC gets from the wall jack to a site like whatsmyip. If they are different you likely have a private ip.
It maybe easier to just call the provider and ask them if you can hook a switch to the jack
Now you could just buy a cheap router and it would work on either but you likely spend $50 for a router.
