I'm building a new rig with the Asus Maxiumus Hero XIII and the Fractal Design 7 Compact case. Everything was fine until I started connecting cables.
The Design 7 comes with one USB 3.1 Gen 2 cable and the motherboard has two slots for USB 3.2 cables. Both are 20 pin connectors and have a notch to ensure you plug it in correctly. When I couldn't get it to plug in, I removed my heatsink, graphics card and motherboard to slide it in because Asus (in their infinite widsom) do not provide upright connectors only side connectors.
What I've found is that the 3.1 Gen 2 does not fit the 3.2 at all. They appear to be the same size but are not. Also, one of the connectors on the Asus motherboard has fewer pins than the other despite the manual showing they are the same. While I wait for Asus support to open, does anybody have any suggestions as to how to make these two work?
I read prior to purchase that these variations of USB were backwards compatible and they appear to be but are not.
