How to copy system file from cd or usb hdd to C: drive whe..
john
Splendid
Aug 25, 2003
3,819
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hello Folks.
I think I got carried away removing files via Spybot S+D ...
Computer with xp pro won't boot after cleanup with spybot .. cleaned
lots of Green coloured files found by spybot.
...Now get message " windows\ ...\ system file is missing or
corrupted "
I have a copy of that file on a Ghost image disk ( the whole image
also is somewhat corrupted + can't be reloaded ] but the system file
is retrievable + now copied to a cd disk.
QUESTION: How can I copy the missing/corrupted system file from a cd
to the c: hdd if windows won't boot ??
I don't have the original XP cd.
I have the " Ultimate Boot Disk cd " via PC World site link, but I
can't figure out how to replace that file from a cd.
Any help gratefully rec'd. Please post to NG. Thanks, -JS
Hi
Is this the error message:
"How to Recover from a Corrupted Registry That Prevents Windows XP from
Starting"
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q307545
Will Denny
MS-MVP - Windows Shell/User
Please reply to the News Groups
<question authority@home.org (john)> wrote in message
news:41a00caa.3429122@news.telus.net...
> Hello Folks.
> corrupted "
Depends on your file system. If you have FAT32 then any DOS boot disk/cd
should do. Go to http://www.bootdisk.com/ and download one if you don't have
one. Make sure you get one with CD drivers.
If you have NTFS then it is harder, but still doable. I would build myself a
Bart PE CD (http://www.nu2.nu/pebuilder/), which is a self contained Windows
XP booting directly from CD. With this you can get full read/write access to
your NTFS partitions, and you can copy any file to your system.
Hello Andre.
Yes, the c: drive on unbootable machine with xp is formatted in NTFS.
I'll follow the below link + try making the NTFS accessible boot cd.
Thanks
On Sun, 21 Nov 2004 11:34:58 +0100, "André Gulliksen"
You can get a copy of NTFS Read for DOS here
http://www.ntfs.com/products.htm which you might be able to use to copy the
file from the CD to your HD. If you have a Windows XP CD you could just run
a Repair Install instead http://www.webtree.ca/windowsxp/repair_xp.htm
Harry Ohrn MS-MVP [Shell/User]
> Hello Folks.
> corrupted "
Hello Again.
I went to below pebuilder site, but the download requires win xp to
create pe disk; I have only win 98 on my only working computer.
-JS
> copy the file from the CD to your HD.
If the HD partition is NTFS he needs NFTS write, not read.
