[SOLVED] How to disable beep sound when pc turns on?
May 14, 2021
So everytime I turn on my pc it makes a quick beep sound I guess to let me know its powering on, however sometimes it can be annoying so I just want to disable it. Its not coming from the speakers because they are turned off when I turn on my pc.
I'm sorry if I posted this on the wrong forum.
The case has an internal speaker.
The single beep says POST has been successful.
You could unplug the speaker but if POST detects and error you will not get the beep code to tell you what is wrong.
Reactions: dudio and kurdtnz
