Hi,
I have my desktop connected via HDMI to my Samsung ue40j5510 TV and want to listen throughmy Jabra Elite 75t earbuds. I can't seem to accomplish this..
At first I thought I had to change some settings on my desktop but given the fact its connected via HDMI and I can plug in wired headphones in my TV without problems this leads me to conclude the solution should be found solely on a setting on the TV.
In the manual it states I should only go the Sound menu/Bluetooth Audio and then the headphones should appear as an option. This is not the case. When I go to this menu it states it is paired to a Wireless Music Adapter (I assume this just means the built-in adapter on the TV is functioning). It also reads 'select the Samsung Bluetooth Audio devices you want to use and when necessary pair the headphones' but that is as far as I get.
I'm (again) assuming the TV has built in bluetooth and if I read the manual correctly it can connect to both Samsung and non-Samsung headphones.
www.manua.ls
What can I do? Do I need to buy an extra Bluetooth adapter or is there a way to disable the sound output via HDMI from the desktop and can I route the audio through my desktop to my earbuds? In the latter case I would have to buy a bluetooth dongle as my desktop doesnt have bluetooth. I do have a dongle to connect an XBox controller (third party) but this only seems to work for the controller and no other devices.
Any help or direction would be greatly appreciated.
User manual Samsung UE40J5510 (English - 157 pages)
Manual Samsung UE40J5510. View the Samsung UE40J5510 manual for free or ask your question to other Samsung UE40J5510 owners.
