If the drivers are installed, they are enabled. Plug a cable into the router and your Ethernet port, and establish WiFi connection. Open terminal, execute "ifconfig" - you will see both eth0 and wlan0 interfaces having IP addresses.
Normally ifplugd is active and will autoswitch between wireless and wired (disabling the other interface in the process). Priority is given to wired.
