News How to Fix 3D Prints Not Sticking to the Bed
I don't understand why printers still have this issue, my tevo tornado from 2017 has a textured surface and everything sticks to it 🤷🏼‍♂️
Never had to use glue or hair spray to help adhesion.
Thanks for this informative guide. I think its time I change my bed as I suspect that could be the issue.
Honestly it's never the printers fault, it's almost always the user. Printing on bare glass is easy if you have your z offset properly calibrated, proper temps and dawn dish liquid cleaned bed, you have an upper advantage because of the black coated bed but I must warn you they do wear out(less stick) and I haven't had a bed adhesion issue since my first days of printing because of NanoPolymer adhesive and knowing exactly what a good z offset was, I currently use that and magigoo because they're both pretty much the same in the way they perform. One thing thousands of people do is grab a sticky note to set z offset, WRONG a sticky note can easily be squished more than it is and give you the idea that your z offset is perfect yet its probably never the same each time. A metal feeler gauge has my nozzle offset perfect every time on the first try because I use a .05mm, squish the hot nozzle onto it(right when I feel resistance I know it's touching) then lower the nozzle .05mm and I know I'm at true zero. Another fun topic of conversation is customers blaming the filament company for a poorly wound spool,WRONG. If you think about how a Coil is wound (and how fast) the single strand NEVER overlaps, yet another user error they don't even know is themselves.
Sweet baby jebus thank you.
I never thought of using a feeler gauge for this, but I tried it just now.
blah blah blah...I just got the best full bed print test ever.
Reactions: GoguyT3d
I experienced issues only during the early days of 3D printing but now as long as the issues addressed in this article are okay I have never experienced it again.
